miked Posted March 15, 2004 Share Posted March 15, 2004 I Have something really weird and i need your help ! 1993 gs 300 w 67k . When i check the tranny fluid cold it is 1 1/2 over the full hot mark ! when i run the car for one hour it shows less on the stick. I thought warm fluid expands ! Any ideas what the problem could be ? And why cold would it be so high ? thx for your help ! great site ! Quote Link to comment Share on other sites More sharing options...
miked Posted March 15, 2004 Author Share Posted March 15, 2004 Guys one more question . On the dipstick what would 1 1/2 " equal to quarts ? Thx Quote Link to comment Share on other sites More sharing options...
TurboGS300 Posted March 15, 2004 Share Posted March 15, 2004 It will show higher when the car is not running as fluid has drained back into the pan from other areas. 1 1/2 is equal to quarts. If you have no probs , I wouldn't worry about it till you are ready to change it. Which should be pretty soon if it's dark colored. The tranny holds 14 quarts, if you cange it by draining you're onlu getting to 6 quarts. So take it to a shop and have them do a tranny flush and exchange. Quote Link to comment Share on other sites More sharing options...
miked Posted March 15, 2004 Author Share Posted March 15, 2004 turbogs, thx for responding - ok so the fluid is droping back into the pan - ok thx wonder why the manual says it should be lower -stupid one big question you believe that 1 1/2 inches on the stick represents 1 1/2 qts??? thx Quote Link to comment Share on other sites More sharing options...
jbarhorst2 Posted March 15, 2004 Share Posted March 15, 2004 How did you check your fluid?? Did you start the car, run the gearshift through all the gears and then go back to park?? Also, did you leave the car running? All of these steps should be done before you check the level. Quote Link to comment Share on other sites More sharing options...
TurboGS300 Posted March 16, 2004 Share Posted March 16, 2004 turbogs, thx for responding - ok so the fluid is droping back into the pan - ok thx wonder why the manual says it should be lower -stupid one big question you believe that 1 1/2 inches on the stick represents 1 1/2 qts??? thx It will be slightly lower if you check it with the car running. Don't worry about it, it's not like a motor where it's going to hit the crank if you have to much fluid. If it's dark go ahead and change it , if not sail on! Quote Link to comment Share on other sites More sharing options...
miked Posted March 16, 2004 Author Share Posted March 16, 2004 jbar/turbo, thx ! yea car running 45 minutes shifted gears fr park to low and back ! left it running level ground- 1 1/2" over hot line after running 45 minutes and doing above. drained 2 qts and i measured two qts. stick was then in cool area on stick after 45 min running - see below . problem is unable to get a proper reading ! 1- 1 1/2" over hot after 45 min runn/level/switch gears 2- when cold 2' over hot 3- drained 2 qts (meas. out ) 4- when cold shows at hot full line 5- when running 45 min/level/switch gears- it is in cool level Can draining two quarts amount to 4 or 5 inches or more on the dipstick ?? thx guys- Quote Link to comment Share on other sites More sharing options...
TurboGS300 Posted March 16, 2004 Share Posted March 16, 2004 Sure you got a lexus dipstick, I think you're okay, so stop worrying. Post a pic of the dipstick and note where it's at and go from there. Quote Link to comment Share on other sites More sharing options...
GuyTelefunken Posted March 18, 2004 Share Posted March 18, 2004 It will be slightly lower if you check it with the car running. Don't worry about it, it's not like a motor where it's going to hit the crank if you have to much fluid. If it's dark go ahead and change it , if not sail on! Do you know what happens when there IS too much fluid in the old gearbox? You get a volcanic eruption of hot fluid out of the dipstick tube, leaving a lovely aroma which will most likely be with the car for a long, long time. :o Quote Link to comment Share on other sites More sharing options...
