Bad Water Pump
chazzsrq
One year ago I had my timing belt and water replaced. About a month ago the water pump started making noise. I replaced the water pump and within 60 miles it started making the same noise. Both pumps were tru flow from napa. We went ahead and replaced the pump with a toyota pump and it's making the same noise after less than 60 miles.On close inspection the impeller shaft is bent and is rubbing the side of the housing. Do you have any idea what can be causing this problem. thank you The car is a 2000 rx 300 with 108,000 miles on it.
That is totally weird, the pump especially the Toyota one is very robust....Maybe your tensioner is bad....Also the idlers for timing belt, are they all good? I would suspect the tensioner....
