Fuel Smell Inside The Car.
I have a IS250 AWD LEXUS and every time i start it after it's been parked for more than a few hours, morning and after work, I have the smell of gasoline inside the car for a few minutes. If I change the fresh air setting (default is coming from outside) to circulate inside air only, then the smell is gone. I took it to the shop to have it inspected for any fuel leak but there is none. hepa air filter will help if I have it replaced? or what can I do?,,,,,,,help!!!!
  • 4 weeks later...
Fuel pressure sensor i bet is leaking a little seen it a bunch of times......if your car has had a bla recall id go back to the dealervand have them check it
