02 RX 300 need instructions on how to remove cover on console where the gear selector is located.
I need to change the bulb that lights up P,R,N,D, does not light up. Does anyone have experience with this issue?
Thanks in advance-ED
if you remove the center console trim ,it just pulls off, the one that surounds the shifter and radio you can accses your shifter , not sure how to get to the bulbs.
The only Toyota vehicle I've replaced the shift indicator bulb on is a Camry but I suspect the routine would be similar. On the Camry I had to slide the shift indicator assembly up the gear shift shaft after removing a few screws. Not fun. Bulb was still difficult to replace. The attached diagram shows the bulb in your RX.
post-2157-0-80088400-1362703642_thumb.jp
