SycamoreAlignment Posted February 27, 2013 Share Posted February 27, 2013 I have a 2000 RX300 (202000 miles) and the wipers work but no longer have functioning washer fluid. Cleared lines, it seems to be washer signal switch (edit: wiper switch) and I have the part but don't know best way to install it. Any advice, guidance, step by step would be great. I hope I don't have to worry about airbag. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted February 27, 2013 Share Posted February 27, 2013 What is a "washer signal switch"? Is this a part of the steering column switch assembly? The most common cause of failure of the windshield washer system by far is failure of the electric pump attached to the washer fluid tank. Quote Link to comment Share on other sites More sharing options...
SycamoreAlignment Posted February 27, 2013 Author Share Posted February 27, 2013 I assume I will have to replace the wiper switch itself, the whole thing. What I am concerned about is getting into the airbag or setting that off. I have a electrical manual but it doesn't show me exactly what I would be getting into. The airbags always worry me. Any advice or a diagram would be greatly appreciated. Nice Spaceballs avatar by the way. Classic! Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted February 28, 2013 Share Posted February 28, 2013 Disconnect the car battery and wait the specified amount of time before you go mucking around and you won't have to worry about the airbags. Are you certain that the problem is in the wiper switch? (i.e. have you used a test light to see if power is getting to the washer fluid pump?) Spaceballs avatar? That's a photo of me. Quote Link to comment Share on other sites More sharing options...
