SteveLexus82 Posted January 2, 2013 Share Posted January 2, 2013 My Climate Control has the Light working and is not black in the lcd screen.. But it is totally non functional.. None of the buttons work and nothing comes up on the screen.. Please help its cold out there and no heat nor rear defrost.. Quote Link to comment Share on other sites More sharing options...
Steve Posted January 3, 2013 Share Posted January 3, 2013 Hmmm maybe your control board is faulty or maybe the cold weather has affected the board that controls it. Not sure if fuses come in to this but have you checked your fuse board too? Quote Link to comment Share on other sites More sharing options...
UCF3 Posted January 7, 2013 Share Posted January 7, 2013 Doesn't the knob work anymore? Quote Link to comment Share on other sites More sharing options...
SteveLexus82 Posted January 13, 2013 Author Share Posted January 13, 2013 Nothing works and had the same issue all summer.. Never drove it until now and didnt bother fixing it in the past.. purchsed it with that issue already there.. fuses are alll goood. Quote Link to comment Share on other sites More sharing options...
SteveLexus82 Posted January 14, 2013 Author Share Posted January 14, 2013 I found a few topics on this but noone gives a straight answer.. The lighter isnt working and neither is my climate control.. But the fuse is good and there is nothing stuck in my lighter.. Please help looking for some advice.. Dealer said about 300 just for diagnostics.. Quote Link to comment Share on other sites More sharing options...
SteveLexus82 Posted January 14, 2013 Author Share Posted January 14, 2013 There is power on one of the wires running to the climate control and the lights on it light up in the evening when you turn on the interior lights.. the car only has 84000 miles on it and im the second owner.. no accidents floods or anything.. This issue has me startled.. Quote Link to comment Share on other sites More sharing options...
SteveLexus82 Posted January 14, 2013 Author Share Posted January 14, 2013 I purchased the vehicle with this issue and got a real good price but dont want to spend a fortune fixing it.. Quote Link to comment Share on other sites More sharing options...
grnsc40095 Posted January 17, 2013 Share Posted January 17, 2013 Look into post 6 and 16 on page 2 in the link below, if no success it might be a dead unit and need to be replaced. Make sure you get the right year for proper function as shown below what years are compatible. http://www.clublexus...functional.html CC units between the years are not compatible 91-93 94-96 97-the rest all have different model numbers and will give you only 2 fan speeds low and max if you switch between them. Quote Link to comment Share on other sites More sharing options...
BADAZLEX Posted August 14, 2013 Share Posted August 14, 2013 I had the same problem on my 94 sc400. I found a wire broken on the temp sensor it's to the left of the radio wrapped in foam tape. I fixed wire and boom i had the coldest ac start to blow. Quote Link to comment Share on other sites More sharing options...
king_eric_the_red Posted December 1, 2015 Share Posted December 1, 2015 Good evening, I really purchased a 97 sc400 and the car has 116678 miles, looks and runs great. Took it Advance Auto to check the battery and electrical system and found that the battery and alternator needed to be replaced. But, my problem is with the CC. All of a sudden the CC display cuts off and the air stops working when the button on the gear shift is depressed. The air was working fine but the issue recently began to manifest. Can someone please give me some insight. Thanks in advance.... Quote Link to comment Share on other sites More sharing options...
