Kris Price Posted October 27, 2012 Share Posted October 27, 2012 I have a 1995 es300 and the OD light keeps blinking. The car runs and shifts fine. The code given is PO773. What is this for and how do I fix it or have it done. I want to know in general the process and cost, before I take it in. Thanks, Kris Price Quote Link to comment Share on other sites More sharing options...
James Horning Posted October 27, 2012 Share Posted October 27, 2012 Shift solenoid E electrical malfunction. ( shift solenoid valve SL) . Open or short in this circuit . A. Open / short blue/ yellow wire at connector E2 to pin 27 connector E7 at the ECM. B . Valve itself is bad. C. ECM D. Check for rodent damage or corrosion, dented trans. Pan, ( damaged wiring or solenoid. F this is one wire, ECM controls has ECM power supply , to solenoid , and ground . This is a electrical code !!!!! Quote Link to comment Share on other sites More sharing options...
pj8708 Posted October 28, 2012 Share Posted October 28, 2012 Shift solenoid E electrical malfunction. ( shift solenoid valve SL) . Open or short in this circuit . A. Open / short blue/ yellow wire at connector E2 to pin 27 connector E7 at the ECM. B . Valve itself is bad. C. ECM D. Check for rodent damage or corrosion, dented trans. Pan, ( damaged wiring or solenoid. F this is one wire, ECM controls has ECM power supply , to solenoid , and ground . This is a electrical code !!!!! Wow James, you really helped this member out. Members with your technical knowledge are extremely valuable to the Club. I hope that you will be willing to jump in more and help others with your outstanding knowledge. Thanks James, and hope to talk to you more around the site. Paul Quote Link to comment Share on other sites More sharing options...
