flying monkey Posted September 18, 2012 Share Posted September 18, 2012 I used the step by step instructions that I got off this website to remove the old hub and everything went great. When I put the new one on is where the questions start. How tight do you put the axle nut on? I found out that you can tighten this down to the point that the hub won't turn. What kind of torque should be used on the hub assembly bolts? (four off them) I stopped for the night so that I could ask my questions and not damage anything until asking here. Thanks. Quote Link to comment Share on other sites More sharing options...
lenore Posted September 18, 2012 Share Posted September 18, 2012 axle nut is 180 ft.lbs and hub assembly bolts are 75 ft/lbs Quote Link to comment Share on other sites More sharing options...
