sanjaysrr Posted August 31, 2012 Share Posted August 31, 2012 This morning the Engin check & VSC light came on after I applied hard break while driving on highway. I read previous comments, my oil change was done almost 3500 KM (2100 Miles) before, so its not new, gas was filled a almost a week ago. Could this still be a problem of air hose. My Toronto (GTA) area Lexus dealer is a bit greedy and I am sure they will try to get as much as possible. can I drive for 2-3 days before I go the mechanic or asap? Quote Link to comment Share on other sites More sharing options...
Steve Posted September 3, 2012 Share Posted September 3, 2012 Hi Go to a 3rd party garage and get them to put a diagnostic check done, good place to start. You need to get the codes first. It may be a dirty MAF sensor or a Pre Cat Sensor. I am pretty sure if it was MAF sensor you would go in to crawl mode. Quote Link to comment Share on other sites More sharing options...
fernandolpa Posted September 16, 2012 Share Posted September 16, 2012 I had the same problem some time ago. It was the Oxigen sensor in the exhaust. First it was the fornt one, I took the car to Lexus dealer = 350 euros! Then the second time I investigate a bit, find the OEM part, buy it by ebay (new), replace by miself and done for 90 USD. I was driving for around four weeks each time with the light on, and there is nothing involved, except that the traction control does not work (I have an AWD) and I guess that the VSC either. Quote Link to comment Share on other sites More sharing options...
