Bly Posted July 14, 2012 Share Posted July 14, 2012 I think I have a clogged fuel filter as I have a very intermittent cough that seems to improve for a while when I treat the fuel with cleaner. It happens so rarely that it's been tough to isolate. I thought that there was no fuel filter on this car but I see that the part is available for about thirty bucks but I don't know where it is or how to change it. For all I know it's in the gas tank. Has anyone changed the fuel filter and if so, how? Thanks Quote Link to comment Share on other sites More sharing options...
pj8708 Posted July 15, 2012 Share Posted July 15, 2012 It is important that every member include the model and year of their Lexus. Other wise, there is no way to begin to help you. Please go to your profile and add this information. Most Lexus models have the fuel filter in the gas tank along with the filter. This placement keeps the pump cool. I'm sorry, but I don't know how to change the filter. Others will chime in here who can help you. Paul Quote Link to comment Share on other sites More sharing options...
Bly Posted July 16, 2012 Author Share Posted July 16, 2012 Of course, you're right. It's a 2002 SC430. I hope it's not in the gas tank although I have a feeling that it is. Anybody have any experience doing this on a 2002 SC430? Quote Link to comment Share on other sites More sharing options...
Bly Posted July 27, 2012 Author Share Posted July 27, 2012 OK, here's how to replace the fuel filter on a 2002 SC430. I'm sure later years are the same. Obviously first order the parts. You'll need the filter, the pick up tube screen and you should probably get some clips if you're changing the pick up screen because you'll mangle the old one getting it off. Order a couple because they're cheap and I destroyed the old one getting it off and one new one putting it on. I bought two. If you're not changing the screen you don't need the clips. I'm told that the screen can be cleaned with brake cleaner but I replaced it while I had it all apart. Anyway, first, put the top down so you have room to work and then move the front seats all the way forward. Then I suggest that you disconnect the battery just in case of a spark and of course, no smoking or open flame. Take out the back seat by reaching under it on both sides and lift up. It will pop out fairly easily. On the drivers side you'll see a triangle plate with three plastic nuts and a wire running through it. Take off the nuts and lift. You can slide out the rubber grommet from where the wire runs to give you some play but the wires stay attached. Under the plate you'll see another plate with eight phillips head screws. They don't look like they had an edge for a socket but they do and I needed to put a socket on each of them to break them loose. Then unscrew with phillips head driver. The plate lifts off. Then there is a little plastic locking clip surrounding the fuel line connector. Slide the clip off (mine was yellow) and lift off the fuel line. You'll get some leakage here so this job is best done outdoors. At that point you can lift out the entire assembly. You have to reach in a bit to release the hose that comes from the opposite side of the fuel tank. Slide the clamp down and pull that hose off. Now you have two loose hoses, The main fuel line and the one that runs to the other side of the saddle fuel tank. Carefully lift out the whole thing without bending the sending unit wire. Once out you need to take it apart using two flat head screw drivers on the several plastic clips that hold the whole thing together. Once apart replace part for part from the old filter to the new. The entire fuel pump fits up inside the filter assembly. Once you get the wire connector off the fuel pump itself you can take the part out of the back seat area and have room to work. Assembly is the reverse. The only problem I had was that when it was all done and back together and the car running I noticed that the gas gauge was about a quarter of a tank too high. I had run the tank almost empty before the job. I took it apart again and noticed that the sending unit wire had come off the plastic clip near where the calibration adjustment was. I clipped that back together and reinstalled but the gauge was still wrong. I thought that maybe it takes the computer some time to average fuel level and went to fill the tank. After driving about a mile the gauge came back to where it was before I started the job. I don't know if this will fix my problem. Time will tell but I did see something that I think is strange. While I had it apart I opened up the secondary side of the fuel tank. Just a sending unit there. That side of the gas tank was dry!!!! The main side had several inches of gas in it even though the light on my gas gauge was on. So I'm thinking that maybe my problem was that the pickup on the main side was partially clogged and I was sucking air on occasion from the secondary side into the fuel line and that's what was causing my intermittent skip. Again, time will tell. Quote Link to comment Share on other sites More sharing options...
Bly Posted July 29, 2012 Author Share Posted July 29, 2012 Well, after 47 miles of stop and go without a cough I had two in a row upon starting from a dead stop so I guess the fuel filter was not the fix. Still, not sorry I changed it as it had some crap on it. Next I think I'll change the spark plugs and if that doesn't do it I'll buy one coil pack and switch them out until hopefully I find the problem. Anyone have any other ideas as to what would cause a very intermittent engine miss. It's almost like a momentary stall although the engine has never actually stalled. If anyone is experienced with marine engines, it's like the ignition interrupt stall when shifting a Mercruiser IO. The same kind of feeling. Any suggestions would be appreciated. Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted July 29, 2012 Share Posted July 29, 2012 I doubt if spark plugs are the problem - the original ones in my 2000 LS400 looked like new when they were changed at the specified 120,000 interval. I just saw a thread on another Lexus forum from someone who was surprised that his original iridium spark plugs were in fine condition when he changed them at 160,000 miles. Iridium spark plugs might be considered lifetime if not for the emissions compliance requirement. Have you checked for stored problem codes? Your location says "Please Select". Where's that? You might also update your profile with your model year and model. Quote Link to comment Share on other sites More sharing options...
Bly Posted July 29, 2012 Author Share Posted July 29, 2012 Thanks for the heads up on my profile. I don't think it's the plugs either but they have about a 100,000 miles on them so it can't hurt to change them. I intend to keep the car for a long time. I'm thinking that maybe one of them has a crack or a carbon track on it that once in a while shorts out and causes the stumble. There are no codes. I'd bring it into Lexus or my local guy who used to work for Lexus but the problem is so intermittent that I don't think they'd be able to find it anyway. My feeling at this point is that if I do bring it in eventually I can say, I changed the fuel filter and pickup screen, I changed the plugs, I rotated out all the coil packs and I still have this issue so you don't have to do any of that and can look elsewhere (to things that I don't have the ability to test or change). I'll keep all of you up to date on my progress and hopefully an eventual solution. Quote Link to comment Share on other sites More sharing options...
Bly Posted July 30, 2012 Author Share Posted July 30, 2012 Brought the car in today to my local guy who used to work for Lexus. He plugged in the scanner. No codes at all. We rode around for awhile with the scanner plugged in. Nada! $114.00 later, nada. I'm going to change the plugs and clean up the coil pack boots and see what happens. Maybe a plug or a boot will give me an ah ha moment. I doubt it but I don't know what else to do. I may just have to live with it until it really lets go but I've been doing that for about three or so years! BTW, it hasn't done it again in about forty stop and go miles. Really nuts. Quote Link to comment Share on other sites More sharing options...
Bly Posted September 17, 2012 Author Share Posted September 17, 2012 Well, after almost one thousand miles I think I've solved the problem. When I changed the plugs I found that one plug, the second one in on the drivers side which I think is no. 4 was loose. I replaced all the plugs although the old ones didn't seem that bad but while I had it apart why not? Anyway, it hasn't stumbled in almost 1000 miles so I think the loose plug was the problem. I have no idea why the plug was loose. They were the original factory plugs and had never been changed. The new plug seated on the washer normally. Very strange. 1 Quote Link to comment Share on other sites More sharing options...
