hi,i have 1995 gs300 with 2jzge engine, i bought it b4 3 month i feel it is heavy and not accelerating smoothly, i cleaned thottle body and changed spark plugs, air filter, fuel filter and lubricants, and i used enjector cleaner. but still same.
NOTE: this model of engine have no MAF sensor.
what could be the reason or the solution?!
may be timing? is the distributor adjustable?, plz help,,,
sorry i forgot to say that;
1- few days my water pump stared leaking coolant from water pump pipe.
2- i take my car to shop to check it to diagnose by computer then he said no errors.
But when i try to check codes manually by connecting TE1 and E1 , only cruise control light start flashing as if giving error code no 12, but i didnt know b4 that cruise control light have codes.
no reply ?!!
originally not have MAF SENSOR AND EGR SYSTEM
