Ball Joints Is It A Big Job can any good mechanic change them is there an thing special?
Its not a big job at all. Get original LEXUS parts from sewell with the discount, and don't forget to get an alignment afterwards.
You can save like 300$ if you buy the doorman which is identical to the Toyota arm and has the same ball joint. I've only done the uppers but even with air shocks it only took about an hour each side. Mostly 14-19mm bolts and nuts if I remember correctly. Very easy DIY job IMO.
