speed101 Posted May 6, 2012 Share Posted May 6, 2012 Hey there I am trying to swap my Hydraulic fan with 2 16" electric fans on a 91 Celsior. I see a bunch of tubing coming from my stock fan and it also has a fan fluid reservoir, I was thinking of deleting the fan + reservoir and connecting the existing tubes with a heater core hose coupler, but if I wanted to delete the whole fan system entirely where would I start? would it even work? Thanks Quote Link to comment Share on other sites More sharing options...
steve2006 Posted May 9, 2012 Share Posted May 9, 2012 Is this any help? http://www.lextreme.com/fan.htm Quote Link to comment Share on other sites More sharing options...
speed101 Posted May 11, 2012 Author Share Posted May 11, 2012 Thats for the engine fan with a clutch, thanks for the reply tho! My fan is run off of some sort of ATF fluid and is not connected to the engine by a clutch. a diagram is located in this thread : http://us.lexusownersclub.com/forums/index.php?showtopic=69856 but I wouldnt know where to start on a delete of the system..... Quote Link to comment Share on other sites More sharing options...
speed101 Posted June 7, 2012 Author Share Posted June 7, 2012 found this pretty interesting. http://lextreme.com/forums/showthread.php?p=117318 Quote Link to comment Share on other sites More sharing options...
control_is_dead Posted June 22, 2012 Share Posted June 22, 2012 I dont have this set up any more but its easiest just to make a bracket and pull the fan pump right off. If you still have your AC just cut a plate and mount idlers like so... Quote Link to comment Share on other sites More sharing options...
