Does anyone know where to get the proper color march for the upholstery code number LF 62 of a 98 ls400'
It is a grey with some green.
I only need the front driver seat and to have a custom tannery do it, it will cost $450.00 for a 50 square feet hide.
Or if you need the same color contact me.
I did not want to spend a lot since I'm thinking of getting a LS460 soon. I was quoted $300. for the labor, to recover the driver seat only. That is OK but I can't find a color match close enough to make it look good.
I know about https://www.leatherseats.com
the labor will be another
Then the labor will be at least $500. to install.
If you look under the seat you may find a piece of leather you could cut off and send to the tannery for a color match but bear in mind ageing will have changed the color of the seat so it may not be possible to get a perfect match.
