Can someone please help me correct/ fix this problem? Also! when i drive uphills my car start to smoke! Smells like overheating, but it's not! HELP PLEASE?? :pirate:
So, you filled the washer fluid container yet the warning light stayed on? Check to see if the sensor wires are still attached. It could also be a faulty sensor.
On the smoking problem...not a clue unless your parking brake is stuck on.
