shinewill Posted April 5, 2012 Posted April 5, 2012 My AC works fine with the temp outside is in the 70's. However, it stops when the outside temps go higher. Obviously a sensor. Can anybody tell me how to test or which of the sensors I should focus on? Thanks a bunch!
lexis lexus Posted April 6, 2012 Posted April 6, 2012 I bet you its that micky ficky hydralic ac condensor fan that's not working. Look at the engine as it warms up w/ the AC on full blast on a warm day. I bet you don't see the fan working and when it gets too hot the system just cuts it off as a failsafe. The other problem you may have is the compressor itself which as it's failing gets too hot and then the system cuts off. Lastly it could be a bad expansion valve located up under the dash about 2 hours of work away. These are the 3 key components of the AC system likely to fail, any malfunction prevents the coolant from being cooled and then.... it turns off. LL
