Is It The Ml Amp Or The Ml Sub, That Is The Question..
Just purchased 06 gs300 with navi and ML but discovered that my bass goes in and out thus is it my ML amp or my ML sub that is causing such problem. Any ideas?
I'm with "dcfish". Very unlikely the sub would just keep cutting in and out unless it was a lose connection, but with todays type of wiring harness and snap connections, very unlikey. ML amps in latter models have had problems with amps going out. Order a replacement amp from "dcfish" and that should sovle your problem. CAUTION- They are not cheap., but nothing with a Lexus is.
The ML amp can not be repaired since Mark levinson keeps all their thech specs proprietary and no one, not even Lexus service has the information to know how to repair them. It is a "up-plug and replace" system.
Paul
Edited by Paul A.
