Air Conditioning
hkc
You may need to replace the air conditioning unit, but don't quote me on it. I would suggest taking it to a good air conditioning shop, or Toyota to have it checked out.
Retrofitting is quite easy and inexpensive. You can buy the retrofitting kits at most auto part stores. What I do sujest is that if you do the job yourself just make sure you have the system evacuated. I've done this on several of my toyotas and have had no problems. Also, when your freon is low your compressor will turn off most cars including Toyotas do this. This is a safety feature so that your compressor doesn't burn out. Good luck.
