dscottdc Posted January 8, 2012 Share Posted January 8, 2012 I have a 06 RX 330 AWD that makes a humming/grinding sound when I turn right. The sound is coming from the back near the left rear wheel. I am thinking rear hub assembly but would like some confermation. Quote Link to comment Share on other sites More sharing options...
lemon Posted January 8, 2012 Share Posted January 8, 2012 Wheel bearing probably. Quote Link to comment Share on other sites More sharing options...
AxeBoss2 Posted August 12, 2012 Share Posted August 12, 2012 Rear wheel bearings. I just replaced both of mine. I'll be doing the front in the near future Quote Link to comment Share on other sites More sharing options...
lenore Posted August 12, 2012 Share Posted August 12, 2012 the fronts are a whole new experience....pain in the !Removed!....The entire hub assembly has to be removed and then the bearing pressed out and new one pressed in. I did it twice, once on a RX300 and on my RX400h....First time went well, the second time I actually bent the hub...My $37 job turned into $350 real fast....There are tuturol on Toyota Nation site. Quote Link to comment Share on other sites More sharing options...
les347 Posted November 30, 2012 Share Posted November 30, 2012 Have the humming noise from rear ....dealer said it was my Hancook tires which I purchased from them....said Michelin do not make that sound....have 94K+ miles on RX 330...luckily I have a very extended warranty...so if it is the bearings I guess I'll be okay Will follow up Quote Link to comment Share on other sites More sharing options...
