I have just finished running 4 gauge wire from the battery to the trunk, installed the two amps -4 ch and 2 ch)
ran all the speaker wires, signal wires, remote wires.
i am at the last step of the setup. I just cannot figure out how to replace the stock tweeter with my infinity 605cs component set tweeter.
can anyone give me some help one that please?
thanks in advance.
most good tweets come with a bolt out the back which mount right where the stock ones are
my mb quart comp ones did
tweeter is behind that little triangular black plastic piece on the door.
when i remove it, i see the tweeter held by a push in metal insert and a bolt.
did you have to make any adjustments to the black plastic panel? or did you use the original bolt hole?
