good afternoon
I looked everywhere but could not find ...
and remember to have seen.
I would like to turn the Foglight presisar without lighting the lamp ..
thanks
srry my bad engles!
The fog lights are wired such that they can only be on when your low beams are on. They will turn off when you flash or turn on your high beams. The safety idea is that the fog lights as well as your high beams being on at the same time would simply blind oncoming drivers far too much.
As the fog lights are presently wired, you simply cannot turn them on by themselves. They can be rewired to do so, but you will require an automotive technician who can provide the proper switching and wiring of the fog lights, as well as the required relays and fuses. Trying to do it yourself without the proper understanding is asking for trouble. Read that as very expensive fires, short circuits and melted wiring harnesses.
