taf Posted December 26, 2011 Share Posted December 26, 2011 The cigarette lighter in my recently purchased 1990 Lexus does not work. When I checked the fuses #5 was missing, which controls the lighters as well as security system. When the fuse was replaced the lighter worked but could not get my key out of ignition unless I removed the fuse. I would like to disable the security system without removing the fuse. Any suggestions? Quote Link to comment Share on other sites More sharing options...
steve2006 Posted December 26, 2011 Share Posted December 26, 2011 Hello Tom and welcome to the LOC. The security system should not prevent you from removing the key from the ignition lock,make sure the selector is in park as this will stop the key coming out. Quote Link to comment Share on other sites More sharing options...
taf Posted December 26, 2011 Author Share Posted December 26, 2011 Thanks Steve for your reply. it may sound strange but i can assure you the selector is in park. the only way i can get the key out is to remove the #5 fuse then it will come out easily. a previous owner must have known this, that is why the fuse was not in there when i bought it. the #5 fuse is for cig lighter,theft,shift lock and airbag. any other suggestions? Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted December 26, 2011 Share Posted December 26, 2011 Do the brake lights work? The main thing I remember when my brake light switch on the top of the brake pedal lever failed on the 90 LS I had was that I had to use the shift lock override to move the shift lever out of Park. I don't remember the failed switch making the key impossible to remove from the ignition switch but it was a long time ago and I had the stop light switch replaced the next day. Quote Link to comment Share on other sites More sharing options...
taf Posted December 27, 2011 Author Share Posted December 27, 2011 Thanks Jim for your reply. The brake ligts work just fine. I am amazed that so little is wrong with this car after 21 or 22 yrs. It will just nag me till I can fiqure it out and get the cig lighters to work and not have to use the shift lock overdrive button. But if I never solve the issues it is still an amazing ride and I feel that my son would be safe driving it. Any other suggestions? Quote Link to comment Share on other sites More sharing options...
