Code P0440
nb7275
Bought a 1999 RX300 a year ago. Engine light came on a few months after purchase and code P0440 was indicated. After diagnostics, had new charcoal canister installed, all hoses checked, everything good. Engine light comes on again a couple months later, same code. Couple things were tightened, but nothing serious. Repeat - light and code. Nothing was found. Reset code. Mechanic (Firestone and qualified) said I should probably go to Lexus dealership because their code reader is more detailed for Lexus products and they might find something else. Engine light came on again - same code. Went to Firestone, had it reset to see how long before light came on again. 3 weeks later, light comes on. same code. I haven't reset it yet, thought I'd write something here to get any other ideas. I think the gas cap is ok, and I make sure I set it tight after adding fuel, but I could get a new one and see if that helps. Any other ideas?
  • 2 months later...
Lots of time has passed since your post, so I assume you replaced your gas cap. If not, the following extract from '99 repair manual might help:
"Possible causes are:
* Faulty vapor pressure sensor.
* Fuel tank cap installed incorrectly.
* Fuel tank cap defective.
* Damaged, disconnected or blocked vacuum hose.
* Fuel tank damaged.
* Charcoal canister damaged.
* Hose between fuel tank and charcoal canister damaged."
I just replaced the original cap on my wife's 12-year-old RX...less than $7 for a Motorad version.
