lemon Posted December 6, 2011 Share Posted December 6, 2011 I've often wondered why the caliper pins were different on the rear of the RX (and probably other cars too). While this TSB doesn't give any answers, it does show you which pin goes where. I tried to make it one .pdf, but my scanner ending up making four. This TSB also applies to the RX330 and the RX350. 041620.PDF 041640.PDF 041656.PDF 041709.PDF Quote Link to comment Share on other sites More sharing options...
lenore Posted December 7, 2011 Share Posted December 7, 2011 ok, more info to file away....thank you Quote Link to comment Share on other sites More sharing options...
lemon Posted December 7, 2011 Author Share Posted December 7, 2011 I have a nice TSB if anyone finds water leaking in the back hatch area. However, the fix involves visiting the body shop and welding the seam above the rear hatch strut mounting bracket. It only applies to vehicles with VIN #s prior to a certain number. Quote Link to comment Share on other sites More sharing options...
