Rx 300 Wiper Fluid Doesn't Squirt
Domenico Nelli
Hi,
The wiper fluid stopped squirting out, so I filled the reservoir, but came to find out that it was basically filled. Do the pumps in these vehicles (2000 RX300) go bad? Could it be a fuse? If so, where is the fuse located? I appreciate any help i can get. Thanks,
Dom
Can you hear the pump "activating" when you pull the lever on the steering column? Any grinding sound or anything?
Nope....I just got a pump/motor for the Highlander (P/N 85330-20470) from toyotapartszone.com for $39.30 :) . That identical P/N on the Lexus web site was more expensive :angry: . That should fix it...
Thanks!
