mvweller Posted November 2, 2011 Posted November 2, 2011 My right side (passenger side) brake light recently went out on my '07 ES350. I cannot figure out how to access it to change the bulb. Does anybody know? Thanks, MW
bearone Posted November 2, 2011 Posted November 2, 2011 Hi, I have a '09 ES350 i would think the lights in the back are the same. Inside the trunk behind the tail light is a small panel with 2 tabs pull the tabs back and the panel will come off, than you can access the bulbs. Good Luck!!!
LennyF Posted November 3, 2011 Posted November 3, 2011 My right side (passenger side) brake light recently went out on my '07 ES350. I cannot figure out how to access it to change the bulb. Does anybody know? Thanks, MW Access is through the trunk. There’s a small plastic door on each side to get to the bulb.
kingnba6 Posted November 3, 2011 Posted November 3, 2011 as other people have stated. there should be a panel that will allow you to access the back of the tail lights. simply get your hand in there and twist of the bulb and pull it. swap out the bulb and twist it back into position.
ecnj Posted January 25, 2014 Posted January 25, 2014 My brake light just went out and shopping for a replacement. While shopping around I noticed that one some website indicates that there is a "standard" wiring and also a "CK" wiring. Anybody know if 2009 ES 350 has standard wiring or CK wiring? Does it matter?
ecnj Posted January 25, 2014 Posted January 25, 2014 I am thinking about replacing the brake lights with led... Has anyone tried it? Any comments?
