1st it was the o2 sensor's had those replaced, now the engine light is on again and it's throwing codes 13 (RPM Circuit #2) and 24 (Intake Air Temperature sensor). When u start the car if just sputter's and shut's off unless u give it some gas but once u let off of the gas it shut's off. any suggestions??? thx
Try resetting the codes, and see if it goes away. if it does comeback I'm suspecting the time belt for the Code 13. It's possible one of the teeth might be worn so it might be moving a bit.
The code 24 I'm thinking something maybe wrong with the wiring to the AirFlow meter. look for any loose connections in the plug and the harness.
