What's Leaking
willchris
  • 3 weeks later...
Start by drying everything off as much as possible. Tighten the supply and return tubes at the steering gear. You might get lucky and find that's all you need.
Keep an eye on it and see where new fluid appears. Hopefully not from the steering gear dust cover.
Also keep an eye on the power steering fluid level in the pump reservoir, a constantly dropping level would confirm a leak around the steering rack area although from your photographs it looks fairly obvious.
