skassamali Posted September 19, 2011 Posted September 19, 2011 All, The clip holding the rear vanity mirror doesn't work. It'll hold it up but then I can't bring the mirror down. Any ideas or thoughts on how to fix or where to order a replacement part?
1990LS400 Posted September 20, 2011 Posted September 20, 2011 http://lexus.sewellparts.com sells the rear vanity mirror assembly for $227.23 if you register with an auto forum member name. You can also view the part numbers at http://www.toyodiy.com I suppose you could first take the mirror assembly off and see if you can rig a fix without buying a new one. I'm not familiar with this particular part but I'm guessing that the light lens can be pryed off to expose the screws holding the assembly to the roof -- that's the way overhead light assemblies are usually removed in vehicles made by Toyota.
skassamali Posted September 20, 2011 Author Posted September 20, 2011 anyone replaced this bulb? typical lexus...."please immediately go see your dealer if you need a bulb replaced"...REALLY!? Should I also go if I need someone to wipe my !Removed!? :chairshot:
1990LS400 Posted September 20, 2011 Posted September 20, 2011 Bulb replacement instructions were removed from Lexus owners manuals about 15 years ago. The owners manual for the LS I bought in 1990 had instructions for many bulbs and all the exterior ones. The attached diagram of the rear vanity light from http://www.toyodiy.com might help. I think it shows only two screws or bolts holding the assembly to the roof. I am guessing that the screws/bolts will be exposed if the lens is removed. Does it look like the lens can be pried off with a thin tool such as a putty knife blade? That's usually the way interior lenses on Toyota vehicles are removed. As for your other question ... did you buy the Lexus !Removed! wipe warranty?
skassamali Posted September 21, 2011 Author Posted September 21, 2011 No I declined it unfortunately. Although paying the dealer's labor rate serves the same purpose <_<
skassamali Posted September 22, 2011 Author Posted September 22, 2011 Took the whole thing apart, found one plastic clip that had broken into 3 pieces. Tried superglue and it held up until I put everything back together and then it broke again. B/c of a $.20 clip, I'll have to spend $230 for a whole new fixture. Any ideas on alternatives?
1990LS400 Posted September 23, 2011 Posted September 23, 2011 Any ideas on alternatives? A bit of velcro? Actually, $230 seems pretty low. I spent something like that replace the front center overhead light cluster in my 00 LS when the passenger side light stopped working several years ago. I think it boils down to whether or not you want to keep your car in tip top order. Some people let little issues like this pile up until they seem like a mountain of problems that make them dissatisfied with their formerly nice cars. Fixing issues like this can make an owner feel better about keeping a car a long time while wringing the value out of it. The 04-06 LS430 is a really nice car. I'm not the only one who considers these to be the last desirable cars in the LS series and worth keeping in good order as long as feasible.
