LennyF Posted September 17, 2011 Share Posted September 17, 2011 . Quote Link to comment Share on other sites More sharing options...
LexBob2 Posted September 17, 2011 Share Posted September 17, 2011 I just traded in my '97 ES300 for an "08 ES350. I can't get the windows to operate unless the engine is running. The owner's manual says that the "ENGINE START STOP" switch must be in the "ignition on" mode, but does not have to have the engine running. Any ideas on this.....am I doing something wrong? With your foot off of the brake, press the start button twice and they should work. Quote Link to comment Share on other sites More sharing options...
LennyF Posted September 25, 2011 Author Share Posted September 25, 2011 I just traded in my '97 ES300 for an "08 ES350. I can't get the windows to operate unless the engine is running. The owner's manual says that the "ENGINE START STOP" switch must be in the "ignition on" mode, but does not have to have the engine running. Any ideas on this.....am I doing something wrong? With your foot off of the brake, press the start button twice and they should work. If I hit the START button with my foot on the break the engine starts. Quote Link to comment Share on other sites More sharing options...
LexBob2 Posted September 25, 2011 Share Posted September 25, 2011 I just traded in my '97 ES300 for an "08 ES350. I can't get the windows to operate unless the engine is running. The owner's manual says that the "ENGINE START STOP" switch must be in the "ignition on" mode, but does not have to have the engine running. Any ideas on this.....am I doing something wrong? With your foot off of the brake, press the start button twice and they should work. If I hit the START button with my foot on the break the engine starts. As mentioned, have your foot off of the brake pedal when pressing the start button twice. Quote Link to comment Share on other sites More sharing options...
LennyF Posted September 25, 2011 Author Share Posted September 25, 2011 I just traded in my '97 ES300 for an "08 ES350. I can't get the windows to operate unless the engine is running. The owner's manual says that the "ENGINE START STOP" switch must be in the "ignition on" mode, but does not have to have the engine running. Any ideas on this.....am I doing something wrong? With your foot off of the brake, press the start button twice and they should work. If I hit the START button with my foot on the break the engine starts. As mentioned, have your foot off of the brake pedal when pressing the start button twice. Oops....i miss read you. My bad. thanks Quote Link to comment Share on other sites More sharing options...
