Squeaky Suspension
Drew903
 Share
I'm a new owner of a 2005 GX and I was wondering if anyone else suspension squeaks? It sounds like the springs, but everything seems to be working. I believe most of the maintenance has been done. I don't want to bring it to the dealer for such an item.
Well it could be a few things. I would give your undercarriage a good looking at.It could be the lower ball joint. Check your tires for uneven wear, and inspect your ball joints for torn boots. There is even the possibility you just need at little WD40 or try to using silicone spray where the metal meets the rubber. Lexus maintenance is less expense if you take a proactive approach to these types of problems.
Loading...
 Share
