CARMAN1 Posted September 4, 2011 Share Posted September 4, 2011 HELLO ALL! NEED TO CHANGE 2 BULBS: 1. RT REAR TAIL-LIGHT 2. RT FRONT RUNNING-LT - HOW TO ACCESS BULB SOCKET TO REPLACE? I'M SURE IT'S SIMPLE, BUT IT SEEMS TO BE A COMMON QUESTION ON ALL BUT A 1994 LS400? ANY HELP OUT THERE? THX IN ADVANCE!! <_< :whistles: Quote Link to comment Share on other sites More sharing options...
billydpowell Posted September 4, 2011 Share Posted September 4, 2011 http://www.lexls.com/ Quote Link to comment Share on other sites More sharing options...
steve2006 Posted September 6, 2011 Share Posted September 6, 2011 Welcome to the LOC, please turn your caps lock off and here is the specific link http://www.lexls.com/tutorials/lighting/tintedtaillights.html For the front sidelight lift up the hood and you will see a black plastic tab on top of the light unit, remove the crosshead screw,lift up the tab slightly then get you fingers behind the vertical section of the light next to the headlight and give it a good tug.It is held in with clips but don't worry they won't break. Quote Link to comment Share on other sites More sharing options...
