Airbag Warning Light
dole2000
Have you done anything to the car lately (repairs). If so it may just need to be reset. Mine came on after I did a power steering repair. I had arched a wrench across my alternator terminal and blew the alternator fuse. It somehow afected my airbag light. I reset it and all is well. Check the fuses first. mine is a 91 LS as well. Do a search on it in the forums and you will find the reset proceedure. It's where I figured it out.
CL
Could be a problem with the airbag system, since the light is on. If it is on- chances are that it will not inflate in a frontal crash. I was told by my local Lexus dealer that "10 year" inspection really was nothing at all and it is not required. I guess back in 1990- they was unsure of how long the system would last.
