2005 Rx 330 Windows
showster
Shipped my 2005 Rx 330 to the United Kingdom via ship. Arrived in the UK with a dead battery, battery is now fine, however windows do not lower using master driver side controller. All windows raise/lower when using the indvidual controllers. All windows will not open/lower using remote or with key. Help, all fuses are good.
Try a reset on them. Run them ALL down with the individual inside controllers. All 4 doors. Then run the drivers up with the drivers control and HOLD it for 4 or 5 seconds. If that works, try the others and see if they now work. If not, you may have to do each of them individually. HOLDING it when it reaches the top does a reset on the brain.
