sule Posted July 25, 2011 Posted July 25, 2011 Hi, i am just wondering what will be the signs timing belt need to be replace?also i have some loud noise sometimes when i started my car it is like something is jamming and then it will start but with real loud noise and and strong shake i can see the engine is about to jump out or i better decribe it with a wet matches when atempt to light a wet matches it will light but not like a dry one i have new sparks plugs?any help will be appreciate thanks
DEATH_AWAITS_YOU Posted July 25, 2011 Posted July 25, 2011 Hi, i am just wondering what will be the signs timing belt need to be replace?also i have some loud noise sometimes when i started my car it is like something is jamming and then it will start but with real loud noise and and strong shake i can see the engine is about to jump out or i better decribe it with a wet matches when atempt to light a wet matches it will light but not like a dry one i have new sparks plugs?any help will be appreciate thanks Timing belt replacement due at 90,000 miles. Don't wait for it to break! Shaking engine when starting is broken engine mounts.
lexmaniac00 Posted July 27, 2011 Posted July 27, 2011 Hi, i am just wondering what will be the signs timing belt need to be replace?also i have some loud noise sometimes when i started my car it is like something is jamming and then it will start but with real loud noise and and strong shake i can see the engine is about to jump out or i better decribe it with a wet matches when atempt to light a wet matches it will light but not like a dry one i have new sparks plugs?any help will be appreciate thanks Sule, A violently shaking/rocking engine is not the result of a worn timing belt. I would hypothesize that this problem derives from worn motor mounts. Worn motor mounts will cause an engine to buck or shake in the manner that you have described. It can also cause engine an excessive amount of engine vibrations to enter the cabin. How un-Lexus like, right? Either you or a skilled mechanic should inspect the motor mounts and replace the worn mounts as needed. For an illustration depicting the motor mounts on your '92 SC400 engine, refer to this SC400 engine diagram. Cheers mate!
