Have had good luck up until 130000 mil..codes popping up, and now a transmission problem which the mechanic can't seem to fix...trans repair shop..
intermittently won't shift into 4th.
any suggestion?
Need to know the codes...
no trans codes, parts were replaced...prob intermittent...only code on check eng light is lean fuel..it comes and goes
The car goes into limp mode (no fourth gear) for some engine related codes, that is why I asked. a Bad Knock sensor, or air/fuel sensor, or bad coil pack could cause this.
