ghoody27 Posted May 11, 2011 Share Posted May 11, 2011 My car has 300,000 miles on her and i bought and engine thats only a babu and tryim to find a syep by step on how to swap out the engine thanx so much! Quote Link to comment Share on other sites More sharing options...
ghoody27 Posted May 13, 2011 Author Share Posted May 13, 2011 No one can help huh I just want to swap the enging no tutorials? Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted May 13, 2011 Share Posted May 13, 2011 I've been on Lexus forms for over 8 years and I don't think I've ever seen instructions or a link to instructions on how to swap an engine. I've removed/rebuilt/reinstalled engines/transmissions in other cars (e.g. Mercedes) and doubt if it would be much different for an LS400. Disconnect all wiring and hoses. Disconnect the drive shaft from the transmission. Disconnect the transmission shift linkage. Disconnect accellerator pedal linkage. Remove the radiator if needed for clearance. Remove the hood if necessary for clearance. Disconnect the engine and transmission mounts from the car structure. Lift the engine/transmission unit out of the car with an engine hoist. Yes, I'm probably oversimplifying it. It's mainly a matter of seeing what has to be removed/disconnected before an engine can be lifted out. Quote Link to comment Share on other sites More sharing options...
pj8708 Posted May 13, 2011 Share Posted May 13, 2011 I've been on Lexus forms for over 8 years and I don't think I've ever seen instructions or a link to instructions on how to swap an engine. I've removed/rebuilt/reinstalled engines/transmissions in other cars (e.g. Mercedes) and doubt if it would be much different for an LS400. Disconnect all wiring and hoses. Disconnect the drive shaft from the transmission. Disconnect the transmission shift linkage. Disconnect accellerator pedal linkage. Remove the radiator if needed for clearance. Remove the hood if necessary for clearance. Disconnect the engine and transmission mounts from the car structure. Lift the engine/transmission unit out of the car with an engine hoist. Yes, I'm probably oversimplifying it. It's mainly a matter of seeing what has to be removed/disconnected before an engine can be lifted out. Jim, you truly are a Renisance man! Quote Link to comment Share on other sites More sharing options...
landar Posted May 13, 2011 Share Posted May 13, 2011 Jim, you truly are a Renisance man! Yes he is. He used to look like Gene Wilder! What happened, Kansas? :whistles: Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted May 13, 2011 Share Posted May 13, 2011 Jim, you truly are a Renisance man! Yes he is. He used to look like Gene Wilder! What happened, Kansas? :whistles: I've been called a lot worse. Much, much worse. No, I looked like Froderick (get it? ) Frankenstein. I've long retired from doing major work on cars but I was always amazed after putting an engine back into a car that it started and ran ... and that I never had to use a fire extinguisher which I always held when a rebuilt engine was started for the first time. Quote Link to comment Share on other sites More sharing options...
curiousB Posted May 13, 2011 Share Posted May 13, 2011 My car has 300,000 miles on her and i bought and engine thats only a babu and tryim to find a syep by step on how to swap out the engine thanx so much! i thank uer origanal post wuz so wurded that it didn't seam a saerioos reqeest. But if it was a serious request you could go to this website and join for 24 hours and download the factory original service manual. https://techinfo.toyota.com/techInfoPortal/appmanager/t3/ti;TISESSIONID=wTkcHjYVwZCTmy1LKQpXF8MWbb5p7dT21ByK2vg76xnwLLG9CWg6 Quote Link to comment Share on other sites More sharing options...
pj8708 Posted May 13, 2011 Share Posted May 13, 2011 Jim, you truly are a Renisance man! Yes he is. He used to look like Gene Wilder! What happened, Kansas? :whistles: I've been called a lot worse. Much, much worse. No, I looked like Froderick (get it? ) Frankenstein. I've long retired from doing major work on cars but I was always amazed after putting an engine back into a car that it started and ran ... and that I never had to use a fire extinguisher which I always held when a rebuilt engine was started for the first time. "You must be Igor". "No, it's "eyegor". (get it?) Quote Link to comment Share on other sites More sharing options...
