cenwesi Posted February 22, 2004 Share Posted February 22, 2004 Ok before i start to crawl under the car i would like to know where or what part of the car the oil filter is located and the oil pan bolt. What side of the car do i need to jack up to get at it. Thanks Quote Link to comment Share on other sites More sharing options...
jzz30 Posted February 22, 2004 Share Posted February 22, 2004 jack the fropnt of the car up and take off the engine under cover. on the driver's side of the engine there should be an oil filter( you might need to take one more cover off) the oil drain bolt is on the oil pan. i believe its a 17mm Quote Link to comment Share on other sites More sharing options...
