Greetings all, I'm new to the forum. I have a '93 Lexus ls 400. My issue is that when I turn on my headlights, my transmission fails to operate properly and I have to pull over. Once, I turned off the lights everything operates fine. Any suggestions on how to handle this. Any guidance would be greatly appreciated. Thank you in advance for your help.
Gary
Sounds like the headlights are finding a ground path different from the intended one. I don't know where it is, but it would be a start to find the ground wire for the headlights and check that it is secure.
If you have not done it already, check for broken wires at the left trunk hinge -- absolutely the #1 cause of erratic transmission shifting on the 90-94 LS400. Unwrap the insulation and wiggle each wire to determine if the wire core has broken since a wire core can break without the insulation breaking. If any wires are broken, splice in short lengths of wire -- soldering is best but you can get by for a while with just twisting the connected wires together and wrapping them with tape.
The problem could be caused by something else but check the trunk hinge wires first -- the problem eventually effects ALL 90-94 LS400's.
