hellgrace5 Posted April 21, 2011 Posted April 21, 2011 Hello! I own a Lexus GS300 3rd Gen. The A/C light is blinking and aircond is not cold! I tried swapping all the working relays with the a/c pump clutch relay and still it is flashing. Any advise ?
hellgrace5 Posted April 23, 2011 Author Posted April 23, 2011 @update checked freon pressure it is ok no leaking in piping and connections! Any advise ?
pj8708 Posted April 23, 2011 Posted April 23, 2011 @update checked freon pressure it is ok no leaking in piping and connections! Any advise ? Did a search of this forum and found this thread. Not sure if this will help, but there are other threads under this topic. http://us.lexusownersclub.com/forums/index.php?showtopic=59040
hellgrace5 Posted April 24, 2011 Author Posted April 24, 2011 Yes i did search on the forum and came out nothing similiar :( thanks for providing the thread but seems like situation is quite different. Freon is ok, no leakage, swapped all relay with A/C clutch relay, fuses ok, new battery. Help! :(
1990LS400 Posted April 24, 2011 Posted April 24, 2011 The following paragraph is from the 2006 GS300 owners manual but can be found in the owners manuals for other models: If the air conditioning compressor does not operate, the indicator of the ”A/C” switch will blink. If the indicator of the ”A/C” switch blinks even when the ”A/C” switch is touched again, have the compressor checked by your nearest Lexus dealer. Let's hope it's not compressor failure but that was the problem the one time the A/C button light blinked in a previous Lexus I owned.
