lsrxlex Posted April 17, 2011 Share Posted April 17, 2011 Hi all, Do I have to remove a lot of parts like radiator, some pulleys, timing belt cover, .... in order to just replacing the fan bracket? I couldn't find a tutorial for this job. Please help. Thanks Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted April 17, 2011 Share Posted April 17, 2011 The fan bracket removal is step #20 here: http://www.lexls.com/tutorials/engine/timingbelt.html Quote Link to comment Share on other sites More sharing options...
landar Posted April 17, 2011 Share Posted April 17, 2011 Hi all, Do I have to remove a lot of parts like radiator, some pulleys, timing belt cover, .... in order to just replacing the fan bracket? I couldn't find a tutorial for this job. Please help. Thanks The fan bracket contains a pulley that the fan clutch and fan are mounted on. I think you could get by without draining the radiator and removing if you are careful and are used to working in tighter spaces. Concentrate on removing the fan and clutch from the bracket pulley. You may have to unbolt the fan shroud along with the fan and slide them up/out as one. After that, you should be able to get at the fan bracket bolts(4). Wiggle out the old and put in the new. Quote Link to comment Share on other sites More sharing options...
