Michal London Posted March 14, 2011 Share Posted March 14, 2011 Hi All, recently - after owning the car for 5 months ;) I've checked if the alarm system works... and it doesn't. I did the procedure described in owner's manual: - open window - close the car with the remote - open doors through open window - the alarm should sound.... but nothing happened. I checked OBDII errors and there is nothing. Where should I start? Is it possible the previous owner disabled anti theft system? Also holding "close" button on remote doesn't close windows/sun roof. Quote Link to comment Share on other sites More sharing options...
Mike813 Posted March 23, 2011 Share Posted March 23, 2011 Hi All, recently - after owning the car for 5 months ;) I've checked if the alarm system works... and it doesn't. I did the procedure described in owner's manual: - open window - close the car with the remote - open doors through open window - the alarm should sound.... but nothing happened. I checked OBDII errors and there is nothing. Where should I start? Is it possible the previous owner disabled anti theft system? Also holding "close" button on remote doesn't close windows/sun roof. there is a dealer option i believe called the "c-best" option. the car has to be programmed to open/close the windows with the keys. maybe the old owner of the vehicle never had it programmed? i would try removing the power from the battery for a bit and hope for the best. its a long shot but its a try. does the panic button work? Quote Link to comment Share on other sites More sharing options...
