rptam Posted February 25, 2011 Share Posted February 25, 2011 Does anyone have any good ideas for cleaning the exhaust tips on the rear bumper of the LS460? Quote Link to comment Share on other sites More sharing options...
pj8708 Posted February 26, 2011 Share Posted February 26, 2011 Does anyone have any good ideas for cleaning the exhaust tips on the rear bumper of the LS460? I have wondered the same thing re: the exstensions on the 2010 ES350. I can't determine if they are real chrome or another alloy. I would think the two cars tips would be made of the same material. Hopefully someone will chime in. If not I'll call my friend at the dealer. Paul Quote Link to comment Share on other sites More sharing options...
Brinck Posted February 27, 2011 Share Posted February 27, 2011 Does anyone have any good ideas for cleaning the exhaust tips on the rear bumper of the LS460? I have not had to do this on my Lexus, but I have exhaust stain problems on my airplane and have successfully used GO-JO nand cleaned with NO pumice Apply to the exhaust stained area, let it sit for 5 minutes, then wipe off. May need a second application. Hope this helps Allen 1 Quote Link to comment Share on other sites More sharing options...
pj8708 Posted February 27, 2011 Share Posted February 27, 2011 Thanks Brinck, I'll buy some and try it. Paul Quote Link to comment Share on other sites More sharing options...
SW03ES Posted February 27, 2011 Share Posted February 27, 2011 I use a product called Eagle One NevrDull. Its a wadding polish, so the can is packed with cotton wadding impregnated with the solution and you tear off a peice and use it to polish the tips, and then buff them off. You can use any metal polish though. 1 Quote Link to comment Share on other sites More sharing options...
pj8708 Posted February 27, 2011 Share Posted February 27, 2011 I use a product called Eagle One NevrDull. Its a wadding polish, so the can is packed with cotton wadding impregnated with the solution and you tear off a peice and use it to polish the tips, and then buff them off. You can use any metal polish though. I'll see if I can find it as well. Need a product for my Volvo S80 too. Thanks my friend! Quote Link to comment Share on other sites More sharing options...
Teehtf Posted March 1, 2011 Share Posted March 1, 2011 Here is what I did to finish the tips up, I went to Home Depot to and bought this... http://www.homedepot.com/buy/paint/paint-tools/3m/fine-to-medium-all-purpose-drywall-sanding-sponge-2-pack-78961.html It made the project so much better and knocked them out in 45 min, (YTMV based on how bad your tips are) the sponge takes the build off without scathcing b/c it is a fine grit. You can sand in any direction to get them clean but once you get them clean, sand in the direction then removes the sanding patterns. Then I used Eagle One's Nevr-Dull to polish them up and ta-daaa! Here are some pics. Before & After Quote Link to comment Share on other sites More sharing options...
chrisinmv Posted March 2, 2011 Share Posted March 2, 2011 I use a non-abrasive product from TR Industries called Gel-Gloss...works on a variety of materials around the car and home including chrome and SS. Takes minimal elbow grease, and, cuts through road tar and exhaust stains in no time. It wipes off like a polish. Also-safe on the adjacent paint finish. I bought a $5 can (lifetime supply) at Home Depot in the Paint dept. Works great-good luck! 1 Quote Link to comment Share on other sites More sharing options...
btdt22 Posted August 11, 2012 Share Posted August 11, 2012 I use emory cloth and water . It gives the metal a platinum type look and takes only minutes Quote Link to comment Share on other sites More sharing options...
Pingking Posted August 22, 2012 Share Posted August 22, 2012 I use Simichrome polish (same thing I use on my collector knives). It won't scratch the chrome but be sure to "tape off" the painted areas around the exhaust tips to prevent dulling the paint. I've had to clean mine twice and it's worked perfectly both times. Quote Link to comment Share on other sites More sharing options...
