95 Es300 A/c Doesnt Stay Cold...
lexi 95
lexi95,
Chances are that you are down on refrigerant due to a leak in the system somewhere. Its fairly easy to diagnose and may be fairly cheap to correct, providing your compressor or the cooling radiator inside the heater box aren't where the leak is. Most good garages can do the diagnosis for you. Good Luck!
The expansion valve is probably sticking. This is a very common problem on the mid-90's ES models. It has been discussed numerous times on this forum. Do a search, entering "expansion valve."
CUMan is right. It's your expansion valve. I drive a 94 es300 and mine did the same a few summers ago and I thought it was the refrigerant getting low but my valve was sticking. If a/c is important to you then better get it fixed before summer starts. Cost me around $500.
