My windows and sun roof in my sc stop working the other day I checked the fuse and its not blown I know cause it controlls the power tilt steering wheel I pulled the fuse and the steering wheel didn't work I but it back in and it works so is there a ecu somewhere or a relay that could be bad I need help thanks.
First off; there is more than one fuse for the system. Since you didn't say which you had; go and check all of them. Off the top of my head the "DOME 10A" & "DOOR 30A" fuses powers both windows and moonroof.
I check the fuses that u told me and there fine I guess I will pull all of them and check I hope it is a fuse I don't want to rewire the whole thing
  • 12 years later...
