Lexi470 Posted November 14, 2010 Share Posted November 14, 2010 My local dealer cannot determine what is going on with my 2001 RX. Sporadically, some part of the Traction Control System is detecting wheel spin on dry concrete. For example, sometimes when pulling away from a stop sign, the slip indicator lights up on the dashboard, and the TCS cuts engine power to the wheels. This also often happens when I pull into my driveway. The driveway has a curbed end, and when I go up that curb with the wheel turned to the right, you can hear the "groan" of the TCS and feel the reduction in power to the wheels. This is not something that happens due to heavy acceleration on wet or gravel roads. It is happening during normal driving conditions on perfectly dry concrete. After a few seconds, the TCS finally figures out there is no problem and power is restored, but it is unnerving when it happens. Needless to say, I am not comfortable driving the vehicle now, as I'm worried it may cut power if I do need to get out of the way of an oncoming vehicle or something. Dealer has supposedly checked sensors, "air gaps", tire pressure, diagnostics, etc. No help yet. I'm able to reproduce this when driving around with a technician. They at first thought it was an ac line hitting the engine block. Definitely not... It is going back again this week for another round of "hmm.. that's odd". Any thoughts on this? Thank you! Quote Link to comment Share on other sites More sharing options...
carguy07 Posted November 16, 2010 Share Posted November 16, 2010 Broken/dirty speed sensor or broken reluctor ring. http://www.clublexus.com/forums/rx-first-generation/514345-diy-repair-broken-reluctor-ring-tone-ring.html Quote Link to comment Share on other sites More sharing options...
saz1277 Posted June 5, 2011 Share Posted June 5, 2011 My local dealer cannot determine what is going on with my 2001 RX. Sporadically, some part of the Traction Control System is detecting wheel spin on dry concrete. For example, sometimes when pulling away from a stop sign, the slip indicator lights up on the dashboard, and the TCS cuts engine power to the wheels. This also often happens when I pull into my driveway. The driveway has a curbed end, and when I go up that curb with the wheel turned to the right, you can hear the "groan" of the TCS and feel the reduction in power to the wheels. This is not something that happens due to heavy acceleration on wet or gravel roads. It is happening during normal driving conditions on perfectly dry concrete. After a few seconds, the TCS finally figures out there is no problem and power is restored, but it is unnerving when it happens. Needless to say, I am not comfortable driving the vehicle now, as I'm worried it may cut power if I do need to get out of the way of an oncoming vehicle or something. Dealer has supposedly checked sensors, "air gaps", tire pressure, diagnostics, etc. No help yet. I'm able to reproduce this when driving around with a technician. They at first thought it was an ac line hitting the engine block. Definitely not... It is going back again this week for another round of "hmm.. that's odd". Any thoughts on this? Thank you! Did you ever reach a conclusion on what was happening? I am having the exact same problem with my 2001 RX300 and no shop, including the dealership, has an answer. Frustrating and scary to continue to drive with this ongoing problem! Any info. would be greatly appreciated! Quote Link to comment Share on other sites More sharing options...
