amf1932 Posted November 10, 2010 Share Posted November 10, 2010 Automatic/drive-through car washes are more popular than ever because they save time and hassle. But are automatic car washes safe for your car? In fact, in many instances, they are the "safest" course of action for many car owners who want to keep their car clean. In fact, automatic car washes can be safer for your car's finish than washing your car yourself because do-it-yourselfers sometimes don't use enough water to safely remove dirt; or they wash the car in direct sunlight -- which can burn spots in the paint. Or they use the wrong type of soap -- such as dishwashing detergent, which removes protective wax and leaves a chalky residue on the finish. Or any one of several common mistakes can end up doing more harm than good. Keeping your car clean and the finish looking good can also mean higher resale value when it comes time to get a new car All else being equal, a car with faded paint and a dingy overall look sells for 10-20 percent less than an otherwise identical vehicle that just looks nicer. So how often should you have your vehicle washed? That depends on how quickly it gets dirty -- and how dirty it gets. For some cars, once a month or so is sufficient -- especially if the car is lightly used and kept in a garage. But some cars will need a bath more often -- especially those that are parked outdoors where they're exposed to bird droppings, tree sap and so on, or driven in areas with very long/severe winters, where the roads are salted when it snows. Here are a few important things to keep in mind when it comes to automatic car washes: Be sure it's "brushless" -- Some older car washes still use abrasive brushes (instead of cloth), which can leave small scratches in a car's finish. On older cars with so-called "single stage" paint jobs, light scratches could usually be buffed out; but all modern cars use a "base/clear" system with a thin, transparent layer of clear coat on top of the underlying color coat to provide the shine. Once the thin clear coat is damaged, often the only way to restore the shine is to repaint the damaged area. Another safe bet is "touchless" car washes that use only high-pressure water jets and detergents to clean the car -- without physically touching it at all. There is virtually no chance of your vehicle suffering any cosmetic damage this way. Some areas have "self-service" coin-operated hand washes, which are great for spraying away heavy dirt buildup. You'll usually need to bring your own bucket, wash cloth/sponge and dry towels, though. Watch out for the after-wash wipe-down -- Most drive-through washes use a strong jet of heated air to force excess water off after the car goes through the wash. Many full-service car washes will then have you drive the car (or drive it for you, in some cases) away from the wash area to be hand-wiped by attendants. This is usually OK -- provided the attendants are using fresh, clean (and soft) towels to do so. Be alert on busy days, when lots of other cars have gone ahead of you. If you see the attendants using obviously dirty old rags to wipe the car down, you should say "thanks, but no thanks" -- and drive away wet. Dirt and other abrasives in the rags can scratch the finish just like sandpaper. Simply driving away from the wash and letting air flow over the car to dry any remaining water won't hurt anything -- and is the best guarantee of a no-damage experience. Any lingering streaks can easily be cleaned up at home yourself using readily available spray cleaners designed for just this purpose. (Honda Pro Spray Cleaner & Polish is excellent for this; it also provides UV protection and easily and safely cleans off bugs, tar and road grime, etc. without water.) Hold off on the extras -- A "works" car wash can cost twice as much as the basic wash, but you may not be getting twice the wash for your money. Undercarriage rustproofing, for example, is of dubious value. Effective rustproofing is applied to brand-new metal, in order to seal it from contact with external corrosives such as road salt. Most new cars are extensively rustproofed at the factory during the assembly process; further "treatment" is superfluous -- and a money-waster. On the other hand, if the wash offers an undercarriage bath, it may be worth the additional cost. Jets of water sprayed directly underneath the car can break loose accumulated crud that would be difficult (and unpleasant) to try to remove yourself using a garden hose. It's also important that underbody drainage holes not be obstructed by mud and other buildup; accumulated moisture can accelerate rust or (in the case of the air conditioning system) lead to the formation of mold in the system. The undercarriage bath should help keep those drain holes clear. Do, however, think twice about spray-on wax. This typically adds at least a couple bucks to the cost of the wash and while it doesn't hurt anything, it's no substitute for hand-applied polish/wax. Spray-on "wax" may provide a short-term gloss enhancement, but doesn't protect against UV sun damage the way hand-applied wax does. Ditto the cost of having an attendant spray Armor All (or a similar protectant) on your tires to make them shiny. The cost for this extra can be equivalent to the cost of buying an entire bottle of the stuff on your own. Wheel and tire cleaning is an exception; the heavy-duty cleaners used by the car wash do a great job of removing baked-on brake dust, etc., that can otherwise be a real chore to clean on your own, using over-the-counter cleaners, a hand brush and a hose. It's especially important to keep aluminum alloy wheels clean; brake dust can eventually permanently stain them if it's not regularly cleaned away. Finally: Make sure your car's OK before you leave -- While many car washes will have a disclaimer posted that they are "not responsible for any damages that may occur" as a result of running your car through their wash, that doesn't mean you should automatically absolve them of any damage their equipment or personnel may have caused. If you notice something, ask to see the manager and point it out to him; whether "legally liable" or not, he may offer to fix the problem in the interest of customer relations. And even if he does not, you can still pursue the matter with a higher-up (such as the company headquarters, if the wash is a franchise, as many associated with big-name gas stations often are). If you have a cell phone with a camera, use it to take a photo of the damage in order to support your claim. And it ought to go without saying that you should never leave your purse or other valuables in the car if you use a wash where an attendant will have access to the vehicle's interior. Quote Link to comment Share on other sites More sharing options...
cduluk Posted November 10, 2010 Share Posted November 10, 2010 Good info. I definitely agree that "in general" the touch-less, or even the non touch-less car washes will do less harm then what most people do to their cars when doing it themselves. I've seen people wash their cars in some very STUPID and "scary" ways. First of all, fundraiser car-washes... You know the ones, the ones held by groups of kids holding up signs offering "free" car-washes (for a donation of course). They drop sponges on the ground and still use them, throw towels at each other... completely disregarding the fact that they're probably scratching peoples cars to DEATH. I've even seen someone wash their car with a KITCHEN sponge, yes, a 3"x 5" kitchen sponge! I can't even imagine how much dirt is being caught and spread around with that thing. And of course, drying... I've tried all different methods of drying towels, cotton, microfiber... I've found the microfiber works the best, but it's still not 100%. Nothing beats blowing the water off... Quote Link to comment Share on other sites More sharing options...
SW03ES Posted November 12, 2010 Share Posted November 12, 2010 Paul A posted this in the General Lexus forum too. Its important to note, that over time a carwash with anything that touches your car WILL scratch the paint. They're too harsh and they don't get cleaned. I agree that they are better than not washing a car at all, but they are no substitute for learning how to do it yourself and purchasing the right tools. I can wash my car in 30 minutes, about the time it takes to drive to the carwash...wait in line, let them towel it off, and come home. The end result is much better, safer, & cheaper. Touchless washes won't scratch, but they use harsh soaps that strip wax, and they don't provide you a clean paint surface. One thing people don't think about is hiring a detailer to wash the car for them. They can do it at your home or office, and sometimes only cost a little more than a tunnel wash...or even the same amount... Quote Link to comment Share on other sites More sharing options...
amf1932 Posted November 12, 2010 Author Share Posted November 12, 2010 Paul A posted this in the General Lexus forum too. Its important to note, that over time a carwash with anything that touches your car WILL scratch the paint. They're too harsh and they don't get cleaned. I agree that they are better than not washing a car at all, but they are no substitute for learning how to do it yourself and purchasing the right tools. I can wash my car in 30 minutes, about the time it takes to drive to the carwash...wait in line, let them towel it off, and come home. The end result is much better, safer, & cheaper. Touchless washes won't scratch, but they use harsh soaps that strip wax, and they don't provide you a clean paint surface. One thing people don't think about is hiring a detailer to wash the car for them. They can do it at your home or office, and sometimes only cost a little more than a tunnel wash...or even the same amount... OK Steve.......the next time I drive down to Gaithersburg I'll let you show me how you do it, but you have to do it on my car. LOL :P Quote Link to comment Share on other sites More sharing options...
SW03ES Posted November 12, 2010 Share Posted November 12, 2010 I would absolutely take you up on that! Quote Link to comment Share on other sites More sharing options...
LEXIRX330 Posted November 13, 2010 Share Posted November 13, 2010 Well SW do you think you can do the GX in 30 mins? I am not that far away so let me know I will drive over and start the timer and have a beer or two. Quote Link to comment Share on other sites More sharing options...
amf1932 Posted November 13, 2010 Author Share Posted November 13, 2010 Well SW do you think you can do the GX in 30 mins? I am not that far away so let me know I will drive over and start the timer and have a beer or two. Hey Lexir.....Ya gotta wait in line........I was first. :chairshot: Quote Link to comment Share on other sites More sharing options...
LEXIRX330 Posted November 13, 2010 Share Posted November 13, 2010 :) your first...your first AMF...since he can clean them in 30 mins or so we can come the same day...I will bring the beer and lawn chairs for you and I to sit and watch! :) Quote Link to comment Share on other sites More sharing options...
amf1932 Posted November 13, 2010 Author Share Posted November 13, 2010 :) your first...your first AMF...since he can clean them in 30 mins or so we can come the same day...I will bring the beer and lawn chairs for you and I to sit and watch! :) Never mind, I found somebody else to wash my car. Quote Link to comment Share on other sites More sharing options...
LEXIRX330 Posted November 13, 2010 Share Posted November 13, 2010 Shhh that's wrong! Quote Link to comment Share on other sites More sharing options...
SW03ES Posted November 14, 2010 Share Posted November 14, 2010 LOL, I don't think the GX'd get done in 30 mins! Quote Link to comment Share on other sites More sharing options...
