KB1794 0 Posted November 5, 2010 Report Share Posted November 5, 2010 Hello, Everyone. I have a 2004 RX330 that recently died while running at idle and I have been unable to get it to start. Originally I thought the problem could possibly be bad gas, so I pulled the seats and the fuel pump and drained the tank. After refilling with a fresh tank I still have not yet been able to get it to start. While the seats and carpeting were out I noticed when I turned the key to the on position the fuel pump is not turning on. I ran a wire directly to the pump and it came on, so the pump is working. I think it could possibly be the fuel pump relay, however I have not been able to locate the relay for the fuel pump. Does anyone know where the fuel pump relay is?? Anyone else have any solutions? Thanks, Kevin Quote Link to post Share on other sites
KB1794 0 Posted November 5, 2010 Author Report Share Posted November 5, 2010 I have checked every relay I could find,(4 in engine bay, 4 under dash) however im not sure which is the fuel pump. All of those were good. I have also heard of possibly tripping the impact sensor which can disable the fuel. Is there a way to reset the sensor? (already tried disconnecting the battery) Quote Link to post Share on other sites
