Sign in to follow this
richardrichss
Flapping Noise Between Drivers A And C Pillars
Recently I have had a noise between the A and C pillars. It sounds like a flapping noise, and I thought it was due to the rear A/C at first, but it doesn't matter if I am running A/C, windows up or down, or what speed I am driving. It does happen only when I am driving, but I can't seem to find where wind would be getting into something, if that is what's happening. Any suggestions?
Share this post
Link to post
Share this post
Link to post
you may be able to readjust the door striker so that the door fits a bit tighter. The weatherstripping may need replacement as well
Share this post
Link to post
After tapping, slapping and nearly hitting everything to try and find something loose, I tried something different. I adjusted the front rail on the roof rack. I moved the drivers side forward a little, and the pass side back a little. I then tightened them up as tight as I could with my hand. The result, no more flapping noises. The rail is no longer adjusted straight, but it is off so little that you can't notice from the ground. And I am no longer irritated.
Share this post
Link to post
Loading...
