Beasley RB Posted September 26, 2010 Share Posted September 26, 2010 I am working on changing the drivers side seal on the transmission. I have taken the nut off the axle but I cannot get it out of the wheel hub. It is rusted and/or stuck. All the videos and books just say "remove the axle" or tap gently with a hard plastic hammer and it will come out. Didn't work for me. I worked my way up from a plastic hammer to a small hand held sledge hammer and it won't move. I sprayed liquid wrench and set it set but no joy. I have protected the shaft threads during all the hammering. To those of you that have removed stubborn axles from the hubs, How Did You Do It?? Any tricks or just use a larger hammer? Thank you for your help. 2002 ES-300 Quote Link to comment Share on other sites More sharing options...
SKperformance Posted September 27, 2010 Share Posted September 27, 2010 just loosen the shock at the top and swing it away . Quote Link to comment Share on other sites More sharing options...
